Orbi WiFi 7 RBE973
Reply
arp invalid randomly with RAX200
df2ef2f2f23f2ef
Hi everyone,
I have a RAX 200 with the latest firmware 1.0.10.140. However the below issue existed in previous firmwares too.
Bascially randomly, machines in LAN can't talk to each other and sometimes they fix themseleves after couple of hours or after they are restarted.
When it happens, the arp record of the target machine shows up as invalid(see below, with or without the MAC addresses) on Windows 10. I couldn't get this on iPhone. But the issues happened with iPhone, Windows 10 and RasberryPi.
Interface: 10.0.0.19
Internet Address Physical Address Type
10.0.0.1 xxxx dynamic
10.0.0.2 00-00-00-00-00-00 invalid
10.0.0.7 xxxx dynamic
10.0.0.15 xxxx dynamic
10.0.0.16 xxxx dynamic
10.0.0.20 00-00-00-00-00-00 invalid
10.0.0.28 00-00-00-00-00-00 invalid
10.0.0.32 xxxx dynamic
10.0.0.33 xxxx  dynamic
10.0.0.35 xxxxxx invalid
I am not sure what issue this is. Only started to have this issue after using RAX200. Any settings I need to do in the router?
Thanks!
Message 1 of 3
df2ef2f2f23f2ef
Re: arp invalid randomly with RAX200
Reset de router and did all setup manually again. Now ARP issue seems to be gone.
But, Lan port 1 doesn't assign IP anymore... Had to change to Lan port 2...
Unbelievable.. those issues. Never spent so much time on figuring out router issues. Again I say, never buy Netgear again. Rubbish.
Message 2 of 3
Guru
What CAT# lan cable are you using between the router and wired PC? CAT6 is recommended.
Does any wired device work on LAN port #1?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 886 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
