× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
cable connection between PC and AX12 modem
BartJonges
Follower
The router generate errorcode 6.
What is going wrong?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Guru
Re: cable connection between PC and AX12 modem
You didn't really give us much to go off.
1. you have the RAX120? you put that in the signature. Or what actual model do you have?
2. what firmware is on it?
3. what is giving you error code 6 (details are key)
4. what were you trying to do?
5. what device were you trying on?
We're not there to see whats going on, whats been done, or even what your using. so the more details you give us, the better we can help
Message 2 of 2
Discussion stats
  • 1 reply
  • 426 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
