Dargon
Dec 11, 2020Aspirant
can't find the the DHCP settings on the Nighthawk AX3000 AX4: RAX35
I'm trying to setup a new router for my family, however I can not find the DHCP setting anywhere, the router's menus seem
very simplified and I can not for the life of me find any options related to DHCP except in ADVANCED>Setup>Lan Setup, which is to use the router as a DHCP server.
any help would be appreciated.
> [...] I can not find the DHCP setting anywhere, [...]
I'll bite. _Which_ "the DHCP setting" do you seek? Why? Is there
some actual problem which you are trying to solve? Care to share?> [...] ADVANCED>Setup>Lan Setup, which is to use the router as a DHCP
> server.Yup. And you want to do _what_, exactly?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read? Look for
"DHCP"?- DargonAspirantI'm trying to configure the lease time.
So far as I know, Netgear consumer-grade routers do not support user
control over such DHCP server/served parameters.https://community.netgear.com/t5/x/idb-p/idea-exchange-for-home
I wouldn't hold my breath.
