- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
cannot add a port forward on TCP 1802
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a RAX75 router and it has the latest firmware available. It was recently reset and now I cannot add a port forward for Fantasy Grounds server (TCP port 1802). When I attempt to add the port forward, the router reports that the forward conflicts and to disable UPnP, Remote Management, etc. I went through the router and checked everything and I cannot find anything that could be conflicting. I had this setup prior to the firmward update and it has been working for months but now it won't work. I need some assistance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: cannot add a port forward on TCP 1802
Hello cgbolton1,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
