×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
cannot connect to smart power strip (TP-link-Kasa, KP303)
martinyxx
Tutor
I have a smart power strip (TP-link-Kasa, KP303). Which cannot be connected to my wifi. Also, during connection process, my wifi will disappear. After unplug the power strip and reset the router, wifi will resume normal.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 7
Christian_R
NETGEAR Employee Retired
Re: cannot connect to smart power strip (TP-link-Kasa, KP303)
Hi martinyxx,
Have you had a moment to get in contact with TP-link regarding your power strip?
Christian
Message 2 of 7
martinyxx
Tutor
yes, Tp-link replied that they confirmed the problem come from the router. Request me to contact router manufacturer.
Message 3 of 7
itsmehuey
Luminary
it's a firmware issue.. definitely not an issue with the power strips.. I have the exact same power strips and the exact same model of router (RAX40)... I had the same issues with router firmware version 1.0.3.80 and when I was able to get a firmware update, the update fixed the issue. Mine was a beta firmware but there is a public version (which may have some functionality stripped because that's how terrible Netgear are), but it may solve your issues regarding the power strip causing the router to completely crash. linke to v1.0.3.88 firmware: https://kb.netgear.com/en_US/000062596/
@Christian_R  I'd suggest not straight away considering that it's the fault of the product we're trying to connect to the router, and consider the router itself is faulty. There have been a sleuth of issues reported against the RAX40 and to turn a blind eye to all of them is downright shady.. If you recall a few months back I reported this exact same issue (along with a lot of other issues that 99% of the other RAX40 owners are having)
Message 4 of 7
martinyxx
Tutor
Thank you. I have updated to new v1.0.3.88 firmware. Already run for two days. Look good. I will try to connect the power strip later. Hopefully, it works.
Message 5 of 7
martinyxx
Tutor
problem solved. Thanks.
Message 6 of 7
itsmehuey
Luminary
great, glad the firmware update helped.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2143 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
