- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
cat 5e wire that came with Nighthawk router
- Mark as New
- Bookmark
- Subscribe
- Permalink
My new Netgear router came with a VERY thin black wire that is labeled Cat 5e. All the videos and my current wire from the modem to the router is a thick yellow wire labeled also Cat 5e. Is 5E 5E no matter its color or thickness? Can I use my existing Cat 5E instead of the one supplied with the router? My existing wire is a bit longer and will accommodate where I need to place the router.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you..can I use the thinner one that was in the Nighthawk package to connect my laptop to the router when doing firmware updates to get the wired connection needed?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: cat 5e wire that came with Nighthawk router
yes you can use your existing cat5e cable.
Some debate cable thickness but in a 6ft run, you aren't going to see a difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank you again for your so timely help!
