×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
device management / band use
gundoc
Follower
Hello,
I am trying to isolate devices and assign them to work with the 2.4 band only and have all other devices utilize teh other 2 5Ghz bands.  I am having trouble identifying which device is which on the app they are described as "nwetwork" and everythign is using the 2.4Ghz band causing extremyl slow speeds.
Please any advice.
thank you!
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
Guru
Re: device management / band use
You can disable smart connect so you can choose which to connect to.
What is Smart Connect and how do I enable or disable it on my NETGEAR router? | Answer | NETGEAR Sup...
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 449 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
