× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
eax80 conflicts with ex7700
flyingcrane89
Follower
When both ax600 and ac2200 extenders are connected wireless connectivity randomly drops. Condition clears when either is turned off.
Model: A6150|AC1200 Dual Band WiFi USB Mini Adapter, AXC753|ProSafe 3m direct attach XFP to SFP+ cable
Message 1 of 2
Accepted Solutions
Guru
Re: eax80 conflicts with ex7700
Are you using them both in mesh mode? (same ssid)
Are they in range of each other?
Usually if people need more than 1 extender, its better to run with a full mesh system like orbi that has a controller. The extenders don't have anything controlling them so can end up connecting to each other and not back to the router.
If that's the case, set one of them with its own unique ssid and it should fix the problem.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1075 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
