- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
i have the mk62 and the satellite won't connect to the router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the MR60 and one MS60 satellite and i do the re sync for the satellite and it is blue for about 3 seconds before going back to amber and when i use the wifi it is very laggy. When i try and update the router and satellite and it says the satellite file is incorrect and half the time i cant even get onto the router management website. if anyone knows how to help me please let me know. also in the nighthawk app it shows i have 2 satelite 1s. is there a way to just reset it completely to factory new? or to reset the satelite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: i have the mk62 and the satellite won't connect to the router
Hi Lucci,
You may factory reset your units by holding down on the reset button for 15+ seconds located on the back. After doing so, you should be able to run through the setup assistant again.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Christian_R wrote:Hi Lucci,
Christian
do i have to reset both or just the sattelite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lucci - For now, I would suggest just factory resetting the satellite and attempt to re-sync it back to the router.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’ve done a hard reset on the router and both satellites.
The one that won’t syncs is amber after pushing the syncs buttons on both the router and satellite.
I’ve also done a 30/30/30 on the satellite.
Any suggestions?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
