- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
installation instructions ax6 on a computer
- Mark as New
- Bookmark
- Subscribe
- Permalink
No cell phone. Need instructions for installing my new ax6 router using a computer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: installation instructions ax6 on a computer
AX6 == RAX45/RAX50 model?
Assuming you managed to connect your computer to the wireless (using the default SSID/Network Name and unique Security Key/Wireless Password printed on the product label) or can connect a network cable from your computer to one of the device LAN ports, start here:
Nighthawk AX6 6-Stream AX4300 WiFi Router Model RAX50 User Manual from around p.17 (more reading is always good for learning and understanding of the product) with the chapter 2. "Connect to the Network and Access the Router".
Works exact the same easy way as shown in the QSG, don't worry!
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
