×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
latest rax40 firmware 1.0.3.94 dhcp is broken
dwaynek
i upgraded my RAX40 to the latest firwamre 1.0.3.94 and reset my router many times but couldn't get dhcp working properly after changing the subnet range to 192.168.0.x
it would lease out 169.x.x.x ip addresses to several devices. i ended up reverting back to older firmware.
Message 1 of 2
antinode
Guru
Re: latest rax40 firmware 1.0.3.94 dhcp is broken
> [...] it would lease out 169.x.x.x ip addresses to several devices.
   Not likely.  Addresses in the 169.254.0.0/16 range are generally
self-assigned, because the device got _no_ response to a DHCP request.
You might be seeing a DHCP-server problem, but that problem would
probably be no response at all, rather than a "lease out" of an address
in that range.
      https://whois.arin.net/rest/net/NET-169-254-0-0-1
   Was there anything distinctive about those "several devices"?
(Address Reservations, for example?)
> [...] i ended up reverting back to older firmware.
   Namely?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 632 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
