- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
mesh wifi 6 system
- Mark as New
- Bookmark
- Subscribe
- Permalink
mesh wifi 6 system
Trying to get this set-up but wont connect to my wifi says problem connecting and net gear wont show up in network connections to connect to. sorry if dumb question but new to this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: mesh wifi 6 system
@Scoobie wrote:Trying to get this set-up but wont connect to my wifi says problem connecting and net gear wont show up in network connections to connect to. sorry if dumb question but new to this.
What router do you have?
What firmware is on it?
What modem/gateway are you connecting it to?
You put "won't connect to my wifi". If its a mesh system, it doesn't connect to the wifi. it broadcasts the wifi.
maybe a bit more details and description of the issue would help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
my modem is a sagecom and yes i have a nighthawk mesh wifi 6 system so i dont connect to the netgear wifi just stay connect to my providers wifi because did connect to netgear wifi but couldnt get on any web site and run my apps.Greatly appreciate your help im not very good with connecting modems.
Thank You
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello when i use the nighthawk app to set-up netgear mesh 6 when i start it it says checking internet connection then says issues connecting with Virgin777 which is my internet provider then says go to wifi settings and join your routers wifi networkwhen i go to netgear71 wifi signal is strong but have this showing beside signal strength ! so wont connect just dont know what to do from here can yous please help.
Thank You
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which Sagecom?
What orbi system? There's multiple wifi 6 systems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is a sagecom 5566 name on modem is valerie and a netgear nighthawk mesh wifi 6 system
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Sagemcom is a modem/router combo device. Meaning it has a router integrated with it.
You still didn't put a netgear model. Look at the label for your device. It'll have the model number.
Regardless, you're more than likely having a double nat because you have 2 routers running on your network.
https://kb.netgear.com/30186/What-is-Double-NAT
Options? (use 1 of these, not more)
1. Put the sagemcom in modem only/passthrough mode. Contact your isp with help for this
2. Put the netgears ip address in the sagemcom's DMZ.
3. Put the netgear in access point mode. This disables its router functions. You can still use/control wifi/ethernet, it just leaves the sagemcom controlling the routing aspects.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
