Orbi WiFi 7 RBE973
Reply
netgear nighthawk ax4
Ganz_Anders
Initiate
Hello,
is it possible to make a mesh configuration with 2 netgear nighthawk ax4 devices ?
thus Router to Router ?
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 3
Accepted Solutions
Guru
Re: netgear nighthawk ax4
Mesh? No.
Can you use one in router mode and the other in access point mode? Sure.
You can even name them the same. Devices can roam based on their own roaming protocol. They'll be a little "stickier" than a true mesh system like orbi MK nighthawk but you can do it.
Message 2 of 3
All Replies
Guru
Mesh? No.
Message 2 of 3
Ganz_Anders
Initiate
Tank you for the fast response
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1231 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
