- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
nighthawk ax4 does not recognize password on 5g
- Mark as New
- Bookmark
- Subscribe
- Permalink
works password on 2.4, but does not on 5g
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: nighthawk ax4 does not recognize password on 5g
Do you have the RAX40?
What device is having issues?
all of them?
Certain ones only?
Did you change the password?
Make sure to remove any special characters/spaces from the password.
Also make sure capitalizationj is correct.
- Mark as New
- Bookmark
- Subscribe
- Permalink
rax35,works on 2.4 but not on 5g on all devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
rax35,works on 2.4,but not on 5g on all devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
have you tried changing the password?
check for special charaters/spaces?
forgetting the ssid/password on your devices and reinstalling them?
You're not giving me a whole lot of info. help us to help you and fully describe issues, what you've done to try to fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
can i do a factory reset,and use the password that is on my router incase something was change
- Mark as New
- Bookmark
- Subscribe
- Permalink
can i do a factory reset to make sure i didnt change any passwords
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can factory reset anytime you want. Its pretty simply. Push and hold reset for 7-15 seconds while its powered on. Then just reinstall it.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
