× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
rax120
szulerus
Tutor
rax120
very bad router, update rolled back 2 times, I warn you this is a very expensive router and no help from neggear
Message 1 of 2
Accepted Solutions
Guru
Re: rax120
Well you are posting in the community forums. Are you posting here for help (we are willing to help out) or just venting?
If you're posting for help more details will help us to help you.
What problems are you having? (the more details the better we can help)
what devices are having problems?
Modem your using?
Firmware you're on? Whenever you're changing firmware with these new devices, make sure to reset after you change firmwares. I'd agree that the firmware is pretty new and still kind of beta. The AX devices are still in draft form so its kind of the price that's paid for being on the cutting edge.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
All Replies
Guru
Re: rax120
Modem your using?
Message 2 of 2
Discussion stats
  • 1 reply
  • 2211 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
