×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
rax40 bridged slow wifi
network_noob
I have been noticing my wifi slow down recently and I can't seem to figure out why. I have my centrylinkC1100T set up bridged with an Ax4 RAX40 ax3000 router. I am getting only half of the speed that I pay for. I pay for 100mbps and only get 60mbps at most even 5ft from the router. When I run the speed test that is built in the nighthawk app I get 97mbps but when I run a speed test on any other device I only get half of that. Why could this be?
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 14
Guru
Re: rax40 bridged slow wifi
are you connecting to 2.4ghz or 5ghz?
2.4ghz is much much slower than 5ghz and the speeds you're getting would be understandable if you're on the 2.4ghz.
For faster speeds, make sure your on the 5ghz band.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 14
network_noob
On 2.4ghz I get 50mbps, On 5ghz get 70mbps when I run a speed test 5ft from router, is this normal? Or should it be more like 90mbps?
Message 3 of 14
Guru
if you run the centurylink modem/router in router mode and put the rax in access point mode, what speeds do you get then?
it wouldn't be the first time a ISP supplied modem/router didn't have a proper bridge mode
Message 4 of 14
network_noob
Sorry I'm a noob at this , but I currently have my modem/router from centrylink in transparent bridge mode and all I did on my nighthawk router was set up the PPPOE. I will try AP mode.
Message 5 of 14
Guru
If you put the netgear in AP mode, you'll need the disable bridge mode on the centurylink
Message 6 of 14
network_noob
I reset my modem/router and connected my nighawk router to it. Then I put the nighthawk router in AP mode but now it just tells me that there's no internet connection. What steps am I missing?
Message 7 of 14
Guru
If you log intot the isp supplied device, is it in router mode?
Is it broadcasting wifi and can you connect to it and browe?
Message 8 of 14
network_noob
Yes
Message 9 of 14
Guru
how do you have the rax connected to it?
lan port from isp router  to wan port on RAX?
And the rax is in access point mode?
Message 10 of 14
network_noob
Yes exaclty like that
Message 11 of 14
Guru
If you log into the ISP supplied router, it should be giving the RAX an IP address since its controlling dhcp. Is it assigning an IP address?
Message 12 of 14
network_noob
Yes it is I think but the WiFi very slow and unstable
Message 13 of 14
Guru
What speeds as follows:
Centuryilnk device:
Wired:
wireless 2.4ghz:
Wireless 5ghz:
RAX200-
wired:
wireless 2.4gh:
wireless 5ghz 1:
wireless 5ghz 2:
What device are you testing on?
What speeds do you pay for from centurylink?
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 1314 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
