× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
wifi connected, no internet connection
tslapnicka
Follower
Bought a nighthawk router ( model RAX10) and have wifi connectivity but not internet. Have done a reinstall , a power up but no change. I have Spectrum as my ISP but have not contacted them directly.
What is my best way to get the router functioning.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Guru
Re: wifi connected, no internet connection
What modem/gateway do you have?
Try this:
power off the modem and the router. disconnect all cables from both (even coax from modem).  Wait 2 minutes.
then connect coax back to modem and power it on. give it a couple minutes to fully boot.
Then connect lan cable from modem to wan port on router.
power the router on. Wait a few minutes for it to fully boot.
Then try setup.
Message 2 of 2
Discussion stats
  • 1 reply
  • 675 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
