Orbi WiFi 7 RBE973
Reply
New - RS700S Firmware Version 1.0.7.86 Released
Guru
Enhancement: 04/16/2024
  • Support Singapore region in APS
Bug Fixes:
  • Fixes DHCP IP assignment issue and add option 60/61 for Europe region
  • Fixes DDoS attack with TCP SYNC flooding.
  • Fixes Web GUI crash issue.
  • Fixes Readyshare not able to download large file through HTTP / HTTP
  • Fixes QoS bandwidth control issue
Security Fixes:
Download Link: https://www.netgear.com/support/product/rs700s
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documenta...
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a >factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
After setting up from scratch and the system is working well, be sure to save a new backup configuration to file for safe keeping and save time if another factory reset needs to be done. Saves time here:
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
This article applies to:
Let us know how it works for you...
Message 1 of 14
bobbyp
Tutor
Re: New - RS700S Firmware Version 1.0.7.86 Released
@FURRYe38 - do you know if this release includes patch/fix for the BT UK IGMP proxying issue described here?
Message 2 of 14
ShadowMario3
Apprentice
Glad to see that this fixes the DDoS false positive issue. Support sent me a test firmware fix a while back which worked out. Man issue from before was they kept on appearing every 10 seconds and now, they are basically gone.
Message 3 of 14
Guru
I do not. I presume it may. Something to try if you can and let us know.
Message 4 of 14
Checked for update in Nighthawk app and nothing yet. If any update needed to be pushed out automatically quickly, it’s definitely this one. Common Netgear….
Message 5 of 14
Guru
If you don't see it via Auto Update, then manually load it. Reason why there is the FW file.
NG may not be auto pushing this one.
Message 6 of 14
Ridiculous. Should not have to do that and needs to be rolled out via Nighthawk app.
Message 7 of 14
Guru
Feel free to contact NG support and let them know then.
Good Luck.
Message 8 of 14
If I did manually update, can I do it over WiFi? Or does it have to be ethernet?
Message 9 of 14
Guru
If you have a good wifi connection and close to the router, yes.
Message 10 of 14
I went ahead and manually updated over WiFi just fine using my iPhone.
Message 11 of 14
baforer1954
Guide
This update negatively affected my throughput. With 1.0.7.82 I got 580 mbps download and 510 mbps upload. After the update I got 250 mbps download and 1 Mbps upload. Reverted back to 1.0.7.82 and all is fine.
Message 12 of 14
ShadowMario3
Apprentice
@baforer1954I have noticed this as well, but it's not as drastic of a decrease for me. Before the update, my speedtests were consistently around 2.1 gbps for both download and upload, but after the update, it seems to hover around 1980 Mbps for both.
Unfortunately, I am unable to revert back to an older firmware whatsoever. Don't know if that means my router is bricked or not. Will try to see if a factory reset helps with reverting the firmware.
Message 13 of 14
Guru
@baforer1954 @ShadowMario3 Has a factory reset and setup from scratch been performed to check this?
Message 14 of 14
Discussion stats
  • 13 replies
  • 997 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
