- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RS300, Getting packet burst and latency variation more often compare to my old XR500 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure what's going on but recently I purchased the RS300 and everything seems fine from download speed and upload, certainly getting more compared to my old XR500 router. However, when I am playing CoD Bo6 the packet burst seems to keep happening more and sometimes the latency variation shows up as well. This has never happened with my XR500 router. I checked to see if RS300 has QoS but I couldn't find it. Is there a way to fix this? Should I call my ISP provider or upgrade my modem (I have been using the Cable modem CM1000 for a while now) ? Everything is up to date, and I am not sure if it has to do with channels or the mode such as up to 2.9Gbps, I'm not very tech-savvy. It could be cause I'm using wireless, but never had this issue with my old router.
Please let me know what I should do, thanks!
(Model: RS300, Firmware: V1.0.1.60)
(Internet speed: 1000 download, 40 upload)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RS300, Getting packet burst and latency variation more often compare to my old XR500 router
Where do you see this packet burst?
What happens if you connect your gaming device directly to the back of the CM1000 modem, same then happen or no?
The RS doesn't have a user configurable QoS, it's mostly automatic.
Lets check the CM modems signals and event logs to make sure they are ok.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I mostly see packet bursts in-game, such as in Call of Duty Bo6. It has a built-in interface showing a logo if it's packet burst, latency variation, etc. Connecting to the modem does the same.
Oh I see, will QoS be brought back for the RS300 even if it has an automatic one?
I tried entering and clicking on the URL link but it's just saying the site can't be reached.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The links give how to get to the modems web page and find the modems web page data there.
CM modems web page can be and should be found at 192.168.100.1 with any browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connection status
- Mark as New
- Bookmark
- Subscribe
- Permalink
Event log
- Mark as New
- Bookmark
- Subscribe
- Permalink
Need the data from the CABLE CONNECTIONS section of the modem, Theres a page that looks some like the event logs. Lots of data on that page.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh I see, I will contact my ISP about that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
heres more info
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK that looks good. Power levels are good and only some minor correctables which is only a couple of channels. Nothing major.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Check to see if direct connection happens with the game device directly connected to the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay sounds good, I will update you once everything is good. Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there, here's an update after 2 weeks. I called Spectrum and they checked their end to see about my modem but they said everything looks good and there weren't any issues but they still suggested sending out a technician. The technician came in and said there was loose cable and removed the splitter. From that day, I was still experiencing issues but it was less than before. They also said they couldn't check the event log since it was a third-party device, so they couldn't check any further.
I still see critical, warnings, and notices in the event log from the modem.
Here's an updated log on the upstream and downstream.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Event logs after two weeks
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
