× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Slow download speed shortly after modem restart
Camreckem
I've been having issues with slow download speed on my home network. Initially I thought it was an issue with my ISP's modem/router combo. My speeds would slow to 30mb down from my advertised 500mb down. I would only get 500mb down after restarting my modem/router. I ended up buying a CM2000 modem and a RS200 router but my issue persists. I only get around 500mb down shortly after rebooting the modem. I have replaced the coaxial cable the goes to the modem, that did not change the issue. The following is my cable diagnostic log.
Is this more than likely a cabling issue to my residence that will require my ISP's attention or is there anything else I  can do to remedy this issue?
Cable Diagnostic
Status: Poor
Action:
[Partial Service]
If the Partial Service mode does not go away within a few hours (Click the Refresh button after each step):
1) Make sure the coaxial cable is tightly connected.
2) Remove any unnecessary splitters.
3) Replace any required ones.
4) Contact your service provider for troubleshooting help.
CM Status: Good
Downstream Status: Poor
Partial Service: Poor
Cable modem is in partial service mode. Your service provider might be under maintenance. Most of the time it won't affect your traffic and will automatically clear when work is complete.
Downstream Power Level: Good
Downstream SNR Level: Good
Upstream Status: Good
Upstream Power Level: Good
Current Time: Fri Oct 25 23:53:11 2024
Startup Procedure
Acquire Downstream Channel: 759000000 Hz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
IP Provisioning Mode: Honor MDD IPv4 only
Downstream Bonded Channels (Partial Service)
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 5 759000000 Hz -3.6 42.7 0 0
2 Locked QAM256 1 735000000 Hz -3.4 43 0 0
3 Locked QAM256 2 741000000 Hz -3.4 42.9 0 0
4 Locked QAM256 3 747000000 Hz -3.3 43 0 0
5 Locked QAM256 4 753000000 Hz -3.4 42.9 0 0
6 Locked QAM256 6 765000000 Hz -3.8 42.6 0 0
7 Locked QAM256 7 771000000 Hz -4.1 42.6 0 0
8 Locked QAM256 8 777000000 Hz -4.4 42.5 0 0
9 Locked QAM256 25 117000000 Hz -6.4 40.4 0 0
10 Locked QAM256 26 123000000 Hz -6.4 40.7 0 0
11 Locked QAM256 27 129000000 Hz -6.6 41 0 0
12 Locked QAM256 28 135000000 Hz -6.8 41 0 0
13 Locked QAM256 29 141000000 Hz -6.9 41.2 0 0
14 Locked QAM256 30 147000000 Hz -6.9 41.3 0 0
15 Locked QAM256 31 153000000 Hz -6.8 41.4 0 0
16 Locked QAM256 32 159000000 Hz -6.8 41.5 0 0
17 Locked QAM256 33 165000000 Hz -6.6 41.8 0 0
18 Locked QAM256 34 171000000 Hz -6.4 41.9 0 0
19 Locked QAM256 35 177000000 Hz -6.2 42 0 0
20 Locked QAM256 36 183000000 Hz -6 42.1 0 0
21 Locked QAM256 37 189000000 Hz -5.7 42.3 0 0
22 Locked QAM256 38 195000000 Hz -5.4 42.5 0 0
23 Locked QAM256 39 201000000 Hz -5.3 42.6 0 0
24 Locked QAM256 40 207000000 Hz -5.1 42.6 0 0
25 Locked QAM256 41 213000000 Hz -4.9 42.8 0 0
26 Locked QAM256 42 219000000 Hz -4.9 42.8 0 0
27 Locked QAM256 43 225000000 Hz -5 42.8 0 0
28 Locked QAM256 44 231000000 Hz -5 42.8 0 0
29 Locked QAM256 45 237000000 Hz -5 42.7 0 0
30 Locked QAM256 46 243000000 Hz -5 42.2 585272 165458
31 Locked QAM256 47 249000000 Hz -5 42.8 0 0
32 Locked QAM256 48 255000000 Hz -5 42.9 0 0
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 4 5120 Ksym/sec 36300000 Hz 47.8 dBmV
2 Locked ATDMA 1 5120 Ksym/sec 16900000 Hz 47.8 dBmV
3 Locked ATDMA 2 5120 Ksym/sec 23500000 Hz 48.0 dBmV
4 Locked ATDMA 3 5120 Ksym/sec 29900000 Hz 47.8 dBmV
5 Not Locked Unknown 0 0 0 0.0
6 Not Locked Unknown 0 0 0 0.0
7 Not Locked Unknown 0 0 0 0.0
8 Not Locked Unknown 0 0 0 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 159 300000000 Hz -5.12 dBmV 43.3 dB 296 ~ 7895 4061263 1109784 1136
2 Locked 0 ,1 ,2 ,3 160 918000000 Hz -6.72 dBmV 40.1 dB 2216 ~ 5975 4348269 2345780 458
Upstream OFDMA Channels
1 Locked 3 ,4 ,9 ,10 ,11 ,12 ,13 6 36800000 Hz 42.5 dBmV
2 Not Locked 0 0 0 Hz 0 dBmV
Event Log
Time Priority Description
Fri Oct 25 23:50:51 2024 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:42:15 2024 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:42:15 2024 Notice (6) DS profile assignment change. DS Chan ID: 33; Previous Profile: 1 2 3; New Profile: 1 2.;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:42:15 2024 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: 1 2 3; New Profile: 1 2.;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:41:37 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:41:26 2024 Notice (6) US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 9 13.;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:41:15 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 160; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:40:33 2024 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:40:32 2024 Warning (5) Dynamic Range Window violation
Fri Oct 25 23:40:32 2024 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:40:32 2024 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:40:31 2024 Warning (5) Dynamic Range Window violation
Fri Oct 25 23:40:31 2024 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:40:30 2024 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:40:24 2024 Notice (6) DS profile assignment change. DS Chan ID: 33; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:40:22 2024 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:40:16 2024 Notice (6) TLV-11 - unrecognized OID;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:23:03 2024 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 23:21:21 2024 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 02:36:57 2024 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 00:44:19 2024 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 00:42:34 2024 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 00:42:32 2024 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 00:09:22 2024 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 00:07:40 2024 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Fri Oct 25 00:07:37 2024 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Thu Oct 24 23:44:41 2024 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Thu Oct 24 23:42:55 2024 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=54:07:7d:02:f4:08;CMTS-MAC=60:26:aa:5c:7d:ce;CM-QOS=1.1;CM-VER=3.1;
Message 1 of 4
Guru
Re: Slow download speed shortly after modem restart
What speeds UP and Down are you expecting to see?
Ethernet speed testing at the modem then behind the RS router?
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Message 2 of 4
Camreckem
Expected is 500 down 50 up, actual is ~30 down 50 up. I get 500 down right after rebooting the modem, then 5mins-1hr later it drops to 30 down. Speeds were taken from a laptop plugged directly into the modem with the cat5e cable that came with the modem. Speeds are the same when performed on wifi (within margin of error)
I have an ISP tech coming out Monday, so hopefully that will shed some light on the issue if not resolve it.
Message 3 of 4
Guru
If that is happening with the direct connection to the modem, then the ISP will need to check everything. Have them review the connections status page and event logs data.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 578 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
