- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NBK750 Connector Types
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can anyone tell me what the connector type is that connects the external (and internal) antennas to the Orbi's modem? (inside of the Orbi)
Specifically looking at the external antenna connectors - they are SMA on one side, then connect to the modem with what looks like some sort of MHF connector. Anybody know what the specific connector is? They are roughly 1.8mm outer diameter and 1.05mm tall.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NBK750 Connector Types
Looks like SMA connectors on the NBR unit:
https://www.downloads.netgear.com/files/GDC/NBK752/NBK752_NA_DS.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, not sure about that. Nobody opens up the case and goes inside to see what the internals are. Doing that would void warranty and could damage the unit. Would be no user need to do anything from a internal use standpoint.
You might try looking at the FCC web site to see if they show the NBK750 in there list and generally, they have internal pictures.
I have seen some pictures and some are a quick disconnect kind of tiny wired connector that connects to the board from the antenna.
Possible one of these: https://www.data-alliance.net/mhf-series-mhf1-mhf3-mhf4/
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
