Orbi WiFi 7 RBE973
Reply
AX4200 RBR750 and RBS750 downloading half the speed
zbamboozler
Follower
Recently bought orbi to run a satelite from my room for my PC. With our old charter spectrum router we got steady 200 download speed. Since connecting to orbi we are getting 70-100 speeds. Is this normal or do i need to change settings or return for new product? i tried old router again and it still gets 200 download
Message 1 of 3
Guru
Re: AX4200 RBR750 and RBS750 downloading half the speed
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Armor, Traffic Meter, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi-AX/RBK753S-update-Rock-solid-in-terms-of-speed-and-stability-s...
Message 2 of 3
kolella
Apprentice
Have you checked your lan cables? Are they minimum cat 5e? Go to Attvanced and select "show statistics" what do you see? here is an example of a router and satellite connected with wired backhaul
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 499 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
