Orbi WiFi 7 RBE973
Reply
AX6000 pairing devices
nsapcor
Tutor
I am planning to replace an existing router with the AX6000 and (2) RBX 853 Satellites. My WIFI devices include thermostats and sprinkler controls. For linking/pairing to the network, can I change the network name of the AX6000 to the current network name of the old router and use its password?
Message 1 of 3
Guru
Re: AX6000 pairing devices
Yes of course.
Message 2 of 3
Chuck_M
Mentor
That technique works for MOST devices... but there are probably some out there that you will have to re-pair.  Example, some of my Alexa's had to be manually reset when I changed to the AX6000
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 552 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
