- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Android/iOS App won't looses connection to RBR850 (RBK853) starting with Firmware 3.2.15.25
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, is anyone else seeing this problem? Starting with RBR/RBS 850 firmware upgrade to 3.2.15.25 both Android and iOS apps (adroid latest version 2.5.4.1036) loose connection to my RBR850. After I reboot the system it will connect, but after about 6-12 hours looses its ability to connect and won't reconnect until after reboot. Happens every time. As a test, I loaded the previous firmware (3.2.11.2) and the problem went away. My RBR850 is in AP mode (not router mode). I have uninstalled and reinstalled both Android and iOS Orbi apps with same behavior.
The web gui works perfectly the entire time. The connected devices work perfectly as well.
Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Android/iOS App won't looses connection to RBR850 (RBK853) starting with Firmware 3.2.15.25
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Posted it there - however, this is definately caused by the firmware update to the AP. Previous firmwares didn't display this issue (even downgraded FW and issue resolved, then returned with most recent FW).
ty
- Mark as New
- Bookmark
- Subscribe
- Permalink
I responded there...
