- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Bad Ethernet cord? Advice please!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here is the deal. Have has Orbi (RBK853) since June - ran flawless. ISP had a wide outage last week. Came back fine. Now 2 days in a row our internet has slowed to a crawl (download, upload fine). Reset router and modem- nothing. Then I unplug Ethernet cord to modem and plug PC into modem. Speed is good. Plug Orbi back into modem and then it’s fine. What would cause this ? Resetting does not work, but Unplugging Ethernet to modem and plugging back in does?
Both today and yesterday unplugging Ethernet work- has this happened to anyone else. Advice please!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Bad Ethernet cord? Advice please!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have RBR850 with 2 satellites - latest firmware v3.2.16.22
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I just checked and it is actually the arris TM1602- sorry was away from home and looked up off spectrum site (similar looking modems). Not a router (neither is the other model)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok.
Well if the system was working ok before this ISP outage. I would represume if it's not working now, then the ISP services need to check into this.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
- Mark as New
- Bookmark
- Subscribe
- Permalink
