Reply
CBR750 Downstream LED always blink white light
stardustdron
Guide
My Orbi CBR750 is getting internet connection from my ISP router via LAN connection and its always blink its downstream LED white light all days. I really want to turn it off but in the settings, there isn't such an option for that.
Can someone please help me?
Message 1 of 12
Guru
Re: CBR750 Downstream LED always blink white light
Blinking usually means its scanning for a downstream channel.
do you have a screen snip of the cable connections page? That shows the link status
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 12
stardustdron
Guide
Here's the screenshot of the cable connection:
Message 3 of 12
Guru
Photos have to be approved by a moderator. You can click on "choose file" and add them 1 at a time (only allows 1 per post) and they're accessible right away
Message 4 of 12
stardustdron
Guide
I have attached it as file
Message 5 of 12
stardustdron
Guide
Nevermind, i uploaded it in imugr
https://imgur.com/a/mxFpQgm
Message 6 of 12
stardustdron
Guide
Message 7 of 12
Guru
You have no locked upstream or downstream channels.
Is your connection working? I've never seen one without locked/downstream upstream working. Smiley Happy
Did you get it activated by your ISP?
check your coax for kinks, damage, old/bad/cheap connectors.
Remove any splitters, amplifiers, or attenuators from the line.
Ensure you're connected to the coax where it enters the home to ensure you have a direct connection.
Message 8 of 12
stardustdron
Guide
Yes, its working and its getting internet connection from another router. I only use CBR750 as wifi router so i don't use coax connection.
Message 9 of 12
Guru
That's why you're having issues with the lights blinking.
Its searching for a modem connection when its not setup as a modem.
That model doesn't have an option to disable the modem portion.
Why are you using a different modem? The CBR750 has a docsis 3.1 modem and is one of the more advanced modems out there.
Message 10 of 12
stardustdron
Guide
Im using fiber connection instead of coaxial unfortunately
Message 11 of 12
Guru
Sadly, you'll probably have to put up with it unless you can return it/exchange it for the unit without the built in modem. (RBK750)
A little black electrical tape might help cover the light Smiley Happy
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 398 views
  • 5 kudos
  • 2 in conversation
Announcements
