Orbi WiFi 7 RBE973
Reply
CM1000 and RBK753
hgs71
CM1000 and RBK753
Question 1:  Is the CM1000 a good match for the RBK753 package?
Question 2:  With the RBK753 package, is it possible to run one satelite via ethernet and the other via
WiFi?
Thank you.
Message 1 of 3
Accepted Solutions
Guru
Re: CM1000 and RBK753
@hgs71 wrote:
Question 1:  Is the CM1000 a good match for the RBK753 package?---if its supported by your ISP, then sure. If supported by your isp, it should be good up to gigabit speeds.
WiFi?----yes
Thank you.
Message 2 of 3
All Replies
Guru
WiFi?----yes
Thank you.
Message 2 of 3
hgs71
Thank you.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 503 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
