Orbi WiFi 7 RBE973
Reply
CM1200 and Orbi Mesh?
ssohata
I am looking to upgrade modem to docsis 3.1 and WiFi system.  Cable internet provider is Spectrum Hawaii.  I'm looking at a CM1200.  Is this compatible with Orbi mesh system?  Website just says CM1200 compatible WiFi6.  Thanks in advance.
Model: CM1200|Nighthawk Multi-Gig Speed Cable Modem
Message 1 of 3
Accepted Solutions
KMDonlon
Luminary
Re: CM1200 and Orbi Mesh?
Yes, virtually any modem is compatible with any router. WiFi 6 is just another form of the router sending out WiFi, you will need a WiFi 6 compatible device to take advantage of the increased speeds.
Message 2 of 3
All Replies
KMDonlon
Luminary
Message 2 of 3
Guru
First make sure your ISP supports the model model your looking for.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1956 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
