Orbi WiFi 7 RBE973
Reply
Connecting a second AX4200 system? can I backhaul the second router to the primary?
theworkerbee
Can I add a second Orbi AX4200 system to the first, instead of adding and buying more individual statellites?
Can I connect the second router via LAN to backhaul it to the primary router and have it act as another satellite?
Adding second system package is a much lower cost than buying individual statellites.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Guru
Re: Connecting a second AX4200 system? can I backhaul the second router to the primary?
RBRs can only work in router or AP mode. Not RBS mode.
Message 2 of 4
theworkerbee
Thanks for the clarification.
Would I be able to use the two extra satellites from a second RBK753 system to link to the router in the first RBK753 system?
Or are the satellites specifically paired to they are shipped with in a package?
Message 3 of 4
Guru
Yes. You can use the other RBS with 1st RBR.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 663 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
