Reply
Highlighted
Déconnexion AP mode Orbi RBK852
Good morning
I always have disconnections, it starts with the satellite that disconnects but I placed it at 6m in open field. Then there is the router 2 or 3 times during the day sometimes the same fixed pink while it works.
I made in addition the following adjustments:
I have sonos at home on channel 1, so I'm on channel 5 in 2.4G, there are no nearby speakers so there is little noise.
Cohabitation 20/40MHZ disabled
cts/rts threshold at 2347 and short preamble mode for 2,4 and 5ghz networks as well.
Another problem I have a subscription ISP 1Gbs down and 500 Mbs up,
I check it on an apple tv connected in wifi via speedtest about 960 mbps downlink and 500 mbps uplink, but when I do the test in wifi with a wifi 6 device (iphone 11), I get painfully 330 mbps downlink while I have 500 mbps uplink, weird right?
On the forum there is a lot of disconnection problem on this product, isn't it a firmware problem ? ( I downloaded the last one )
Can you help me
Translated with www.DeepL.com/Translator (free version)
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 23
Highlighted
Luminary
Re: Déconnexion AP mode Orbi RBK852
Your Apple TV is wifi 5 (802.11 ac) and its max speed  is 867 Mbps on the 5 GHz band.
Did you try another wireless device with wifi 5 (ac) on the 5 GHz band?
Did you try another wireless device with wifi 6 (ax) on the 5 GHz band?
Message 2 of 23
Highlighted
My apple tv and gigabit ethernet so no worries,
otherwise I made measurements with wifi 5 and wifi 6 devices and it's the same result : 330Mbps instead of 900Mbps.
But I insist my problem is the disconnections, I have just connected the satellite in ethernet and I have the impression that it works better.
I saw on the forum that this model had problems in access point mode and blackhaul problems.
Model: RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 3 of 23
Highlighted
Luminary
About the frequent disconnections, you might have a lot of electromagnetic interference due to other wireless devices... but if it's not so you might instead have a defective router or a defective satellite.
Message 4 of 23
Highlighted
Guru
 Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Channel 5 should not be set as a manual channel.
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Be sure that CTS and RTS values are changed to 2346 under Advanced Tab/Advanced Settings/Wireless Settings
@Kiki387 wrote:
Good morning
Can you help me
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)>RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 5 of 23
Highlighted
Good morning, sir,
The internet provider is bouygues telecom.
I made your settings but it's not better.
I specify that I'm in access point mode, so the settings are limited for example any unused channel on 5Ghz.
The house is 150m2 and the 2 systems are 7m apart.
There is no Wifi Neighbors near .
Message 6 of 23
Highlighted
the firmware is :
RBK852 Firmware Update V3.2.11.2_1.2.13
Message 7 of 23
Highlighted
Guru
Has a factory reset and setup from scratch been performed since last update?
Does turning OFF the RBS and using the RBR alone still exhibit the problem?
Message 8 of 23
Highlighted
I just did a reset and it's been working for about an hour now.
Thanks
Message 9 of 23
Highlighted
Guru
Is that longer than before?
Message 10 of 23
Highlighted
The satellite just turned pink, so it didn't hold up any better than usual.
Only the router for now is still working.
I don't know what to do.
Message 11 of 23
Highlighted
Guru
What is the building materials made of for the home?
Can you move the RBS out farther? Try 30 feet?
What channels are you using?
Message 12 of 23
Highlighted
What is the building materials made of for the home? plaquatre
it's the same
2 ghz --> 7 et 5 ghz 48
1 more than 100m
firmware 3.2.11.2-1.2.13 which is not automatically downloadable.
so the satellite is jumping all the time I unplugged it and the router works alone but after a while it lights up in fixed pink
Message 13 of 23
Highlighted
Unfortunately I have exactly the same issue as Kiki.
I am trying to fix the connection issues in AP Mode since weeks and couldn't find any fix so far.
Thus, I ordered a new pair of Orbis.. let's see if the issue is caused by faulty units or if it's an issue with the RBK852 in general.
Message 14 of 23
Highlighted
this product has a real problem in AP mode.
Message 15 of 23
Highlighted
Guru
it's the same
2 ghz --> 7 et 5 ghz 48< Try channel 1, 6 or 11. Don't use any of the other channels. 1, 6 and 11 are primary channels to use.
1 more than 100m
You can downgrade the enstire system to v3.2.9.2 and see if anything changes.
Possible that you may have a bad RBS. I would open up a support ticket with NG and if nothing fails to stablize the RBS, ask about an RMA. @Blanca_O
Message 16 of 23
Highlighted
Good morning, sir,
I tried the firmware 3.2.9.2_1.2.4 and the problem still exists
Message 17 of 23
Highlighted
Guru
I would open up a support ticket with NG support and get help on this.
Seems like something if faulty with your system.
There is more recent FW avialble however I doubt it will help fix your issue. The problem seem to persist even downgrading.
Message 18 of 23
Highlighted
I tried with the new firmware 3.2.15.25 but still problems so I unplugged the system for 1 day. I plugged it back in yesterday and miracle it's been working for 12 hours, isn't that due to some information that remains in memory?
To be continued ....
Message 19 of 23
Highlighted
My rbr850 is behind an unmanageable switch
Message 20 of 23
Highlighted
Guru
What is the Mfr and model# of the ethernet switch in the configuration?
Message 21 of 23
Highlighted
DLINK DGS-1008P
Message 22 of 23
Highlighted
Guru
Well this switch does have green ethernet features:
"Conserves Energy
The DGS-1008P 8-Port Gigabit Switch makes use of
D-Link Green™ eco-friendly technology, providing
energy savings, reduced power consumption, and
a longer product life without sacrificing operational
performance or functionality."
Can you connect the RBR directly to the main host router and see if you still seen problems with out the switch connected? I have my 853 system in AP mode connected directly to my main host router with out a switch. Not seeing any disconnections thus far.
Message 23 of 23
Top Contributors
Discussion stats
  • 22 replies
  • 487 views
  • 0 kudos
  • 4 in conversation
Announcements
