- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Devices connected to the orbi rooter & with devices connected to the internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I need help with network configuration. I must admit that I am not at all competent on the subject. I have just purchased and installed an ORBI RBS750.
My orbi rooter is connected to my livebox(internet box) as rooter. So I have 2 rooters: the one from the livebox with addresses in 192.168.1.x and the one from the orbi in 10.0.0.x.
I would like to keep the LAN ports of the livebox active (as a reminder they are limited to 1 Gbps when my fiber shows at 1.5). This therefore allows me to have the possibility of using all my bandwidth and I would like to be able to access a hard drive connected by USB to the box.
My question, how to make so that the network of the orbi can access the network of the Livebox?
I imagine that you have to configure a VLAN which receives me at least at my DD via the sharing and the IP of the box.
Thank you in advance for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Devices connected to the orbi rooter & with devices connected to the internet
Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
If you want the Orbi on the same network as your ISP router, then try option #3 on the Orbi RBR.
@Rodi wrote:Hello, I need help with network configuration. I must admit that I am not at all competent on the subject. I have just purchased and installed an ORBI RBS750. My orbi rooter is connected to my livebox(internet box) as rooter. So I have 2 rooters: the one from the livebox with addresses in 192.168.1.x and the one from the orbi in 10.0.0.x. I would like to keep the LAN ports of the livebox active (as a reminder they are limited to 1 Gbps when my fiber shows at 1.5). This therefore allows me to have the possibility of using all my bandwidth and I would like to be able to access a hard drive connected by USB to the box. My question, how to make so that the network of the orbi can access the network of the Livebox? I imagine that you have to configure a VLAN which receives me at least at my DD via the sharing and the IP of the box. Thank you in advance for your help.
