Orbi WiFi 7 RBE973
Reply
Double NAT issues on Xbox One
NoNameJ
Hardware:
ATT Modem Router Combo: BGW210-700
- device is set for IP pass through (dynamic) per several published videos about how to do this.  also all the other settings were applied as the videos instructed.
-I have changed the IP address to 198.168.18.1
Orbi Router AX 6000
- Orbi Router AX6000 has an IP address of 192.168.20.1
- I have assigned a fixed IP address to the Xbox on the Orbi router.
Nothing I am doing will open up the NAT, please help
Message 1 of 7
Guru
Re: Double NAT issues on Xbox One
Message 2 of 7
BiGMERF
Apprentice
can you put your modem/router combo into transparent bridge mode ?
Message 3 of 7
Guru
HIs modem doesn't support bridge mode.
Message 4 of 7
BiGMERF
Apprentice
What about adding his Orbi to the first routers dmz
Message 5 of 7
Guru
I beleive he mentioned using IP Pass thru currently which simiar to DMZ.
Message 6 of 7
Guru
Any progress on this?
@NoNameJ wrote:
Hardware:
Orbi Router AX 6000
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1727 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
