Reply
Firmware 3.2.16.6 Web GUI bug
Mstrbig
Master
Re: Firmware 3.2.16.6 Web GUI bug
@dtay wrote:
@Mstrbig wrote:
@dtay wrote:
Same problem via the web GUI as well.  I make the changes and it doesn't retain it.  Firmware V3.2.16.22_1.4.9 on 850's.
The latest firmware 3.2.17.12 fixes this issue. Confirmed on both 750 and 850 systems.
3.2.17.12 firmware?  Is that publically (or beta) released?  I don't see it on the website and my RBK850's doesn't detect it.
Glad to hear that 3.2.17.12 fixes it; is there a changelog of what's fixed in that release?
Official:
Download Link:
RBR850 - https://www.downloads.netgear.com/files/GDC/RBK852/RBR850-V3.2.17.12_1.4.14.zip
RBS850 - https://www.downloads.netgear.com/files/GDC/RBK852/RBS850-V3.2.17.12_1.4.14.zip
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
There's always a logical answer, if you have all the facts!
Message 26 of 29
AwesomeQA
Apprentice
Try RBR850 with RBS50 then you’ll see it is not fixed
RBR 50 Firmware Version 2.7.2.104
Message 27 of 29
Guru
I don't use RBS50 with my Orbi AX system. I already have two RBS850s wired and online. I have enough wifi signal coverage.
@AwesomeQA wrote:
Did you try connecting your RBS50 to RBR850 and change devices names.. etc.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v3.2.18.223/SRK30 V3.2.33.106)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, RBK50, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 28 of 29
Guru
I posted this also when v12 first came out:
https://community.netgear.com/t5/Orbi-AX/New-RBR850-RBS850-Series-Firmware-Version-v3-2-17-12-Releas...
Including release notes.
Message 29 of 29
Top Contributors
Discussion stats
  • 28 replies
  • 977 views
  • 1 kudo
  • 7 in conversation
Announcements
