Orbi WiFi 7 RBE973
Reply
Future Mesh Setup
Sheenlee14
Follower
Future Mesh Setup
Question?
I currently own the Nighthawk AX8 8-Stream router and would like to use it with another mesh system. Would it be compatible with the new Orbi WiFi 6 System AX6000 (RBK852)? I do plan on having either of them connected to my pc directly via ethernet.
Just want to know if I should go that route, if I can or should I consider the Nighthawk AX8 8-Stream Mesh Extender (EAX80).
Thanks in advance.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Guru
Re: Future Mesh Setup
RAX and Orbi are not mesh compatible.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 370 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
