Orbi WiFi 7 RBE973
Reply
HikariTV
BopJ
HikariTV
Does Orbi RBK852 work with Hikari TV? If yes what are the necessary setting in Orbi router so that Smart TV 3400 connects?
Many thanks
Message 1 of 3
Guru
Re: HikariTV
I would refer you to the TVs mfr support site for help and information regarding there product and setting it up.
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings for the Orbi settings.
Message 2 of 3
BopJ
Re: HikariTV
Thank you for answering! Unfortunatelly I'm not smart enough to understand,...
I think that I have a basic problem,...I see IPv6 address when I connect to Nuro.jp device (FG4023b) but only IPv4 if i'm connected to Orbi.
This can't be right, correct? Is there a simple way to solve?
FYI I spent hours on the telephone w Nuro and Hikar Support; I don't speak Japanese and I'm not tech savy ,...the 3 way conversations (with translation service) were extremely difficult.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 584 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
