- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issue with Orbi WIFI 6 RBR850
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently purchase the Orbi RBR852 for the second time and I am having an issues that is rather strange. About three day ago I was not ablr to get into the router from the App on my cell and on my laptop. I still have WIFI but could not get in. I unplug the router for about 30 seconds and then tried, I was able to get back into the router on the laptop but still cannot get to the router via the app on my iphone.
I have AT&T 1 Gig, has anyone encountered this issue? And if so how did you resolve it. Thank you for you replies in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issue with Orbi WIFI 6 RBR850
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Has a factory reset and setup from scratch been performed since last FW update using a PC and web browser and walk thru the setup wizard at 192.168.1.1?
Be sure you have a PW setup for the admin log in account for the RBRs web page. The Orbi app should ask you for this same PW for the web page admin login.
