Reply
Highlighted
Guide
Latest firmware drops VOIP and MS TEAMS and Skype
We need the ability to downgrade firmware without the orbi auto update. I am unable to work with all these drops. Every time they issue an upgrade they blow something out of the water. I know of no way to keep a lower firmware without Orbi auto updating
Message 1 of 61
Highlighted
Re: Latest firmware drops VOIP and MS TEAMS and Skype
We are suffering from the exact same problems in our household and our offices are closed for 2 weeks (to start with).
This is unacceptable.
Message 2 of 61
Highlighted
Guide
It absolutely couldn't have happened at a worst time. My Skype for Business conference calls this morning all dropped off at about the 8 to 9 minute mark - every time like clockwork.
My son was complaining about his game streaming dropping all the time at about the same time point since last week but I didn't take it that seriously... Now that it's affecting my new work from home situation this is utterly and completely unacceptable.
Come on Netgear - get with it and fix it.
Message 3 of 61
Highlighted
Guide
Worse part is we no flag to orbi to stop automatic updates. I guess they must think we only use their router for fun.
I work from home and this is killing me.  If I downgrade the stupid orbi it will just re-update again  with the same bad version.  They have ZERO QA processes. This has got to stop. I had an ASUS router for 5 years and never had these issues. Add to that this was 700 hundred dollars.
The best thing they  can do is to give us a setting to stop auto updates since they can't release code that works ever.
Message 4 of 61
Highlighted
Guide
This is what I sent NETGEAR under my case number
I WAS ON HOLD FOR 30 MIN. AND GAVEUP WE ARE IN THE MIDDLE OF A CRISIS IN THIS COUNTRY AND WORKING FROM HOME AND ALL OUR CALLS AND MEETING ROOMS ARE DROPPING SINCE THE NEW FIRMWARE WAS RELEASED. WE NEED NETGEAR TO REMOVE THAT FIRMWARE FROM DOWNLOAD OR GIVE US AN EMERGENCY OPTION TO NOT ALLOW AUTOMATIC FIRMWARE UPGRADES YOU GUYS ARE KILLING US BECUASE CAN NEVER RELEASE FIRMWARE THAT WORKS
Message 5 of 61
Highlighted
Guru
What Orbi product model do you have?
Is these over wired or wireless connections?
For wireless, be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
If this still fails, then try this:
https://community.netgear.com/t5/Orbi-AX/RBR850-Frequent-Disconnects-Starting-March-9th-AM-EST/m-p/1...
My Setup (Cable 900Mbps/50Mbps)>CAX80>XR450 v2.3.2.106(Router Mode)>RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 6 of 61
Highlighted
Guide
I have orbi AX started right after firmware upgrade
Message 7 of 61
Highlighted
Guru
Message 8 of 61
Highlighted
Guide
I changed the RTS/CTS values and will update this post on whether it helped. I have wired and wireless clients - both have experienced the problem. I also realize the RTS/CTS value change only affects wireless but I'm trying anything at this point.
I have the RBR 850 and RBS 850 with the router direct to Verizon FIOS - no cable modem. I am positive this is NOT a Verizon issue. As others have pointed out, all my problems started after the latest firmware update.
Message 9 of 61
Highlighted
Hey guys, update here, I unplugged my RBK852 and hooked up my RB50. Everything has working smoothly for about 4h now, so I say that’s a win! It’s the damn 700dollar system that doesn’t work. Shame
Message 10 of 61
Highlighted
Guide
The support team called me today told me they pulled the lasted firmware from the download site. I am reverting back. This company clearly does not understand what QA means. I had asus router for 5 years never had issues and I paid half of what this piece of junk cost. NETGEAR software engineers simply cannot get it right. Very sad.
Message 11 of 61
Highlighted
Have experienced the exact same issue after auto update. Trying now to revert to old firmware.
Thanks for bringing it to Netgears attention.
Message 12 of 61
Highlighted
Guru
Thanks for letting us know. Thanks for being patient while NG works on this.
Sure is odd that some of us have not seeng this since v10.11 appeared for us. Sure would like to know why there is this disparage between some users.
Message 13 of 61
Highlighted
Guru
Can you downgrade to v3.1 and see if this helps your system? Others are reporting that downgrading is working for them.
Message 14 of 61
Highlighted
Guide
My issues are resolved back on the previous version. NG will do this to us over and over. This has been my experience since installing orbi ax. We need a flag to tell the NETGEAR router not to auto update. You can never trust what they are giving you. In this moment of crisis in the USA with all of us working from home the last thing we need is to have them push new software again and have to go to round 2,3,4, x with them again.
Message 15 of 61
Highlighted
Guru
Glad you got it working.
Message 16 of 61
Highlighted
Guide
How do I downgrade? I was given the new beta by Netgear yesterday but has the same issues.
Message 17 of 61
Highlighted
Guru
You can download files from HG download site and manually install the thru the RBRs web page.
Message 18 of 61
Highlighted
Guide
Unfortunately this has come too late. I had to completely remove my Orbi AX routers and satellites and start using the slower but functioning previous wifi router. I did go so far as downgrading to the previous firmware and still experienced the problems so I invested quite a bit of time to try and stick with this expensive purchase but eventually had to cut my losses and put my old router back in.
Very disappointed.
Message 19 of 61
Highlighted
Haven't had the time nor energy to downgrade put them back up so still on RBK50. Netgear better fix this asap. It's not cheap (non-working) routers they're selling us!
Message 20 of 61
Highlighted
Guru
Did you try a down grade on v3.2.9.2 then re-upgrade to v10.11?
Others are reporting better operation since NG seem to fix issues on there end.
Very disappointed.
Message 21 of 61
Highlighted
Guru
Message 22 of 61
Highlighted
Guru
Any progress on this?
This issue should be resolved. NG has fixed behind the scenes problems that were effecting v10.11FW. Please re-apply v10.11 and factory reset the RBR and setup from scratch.
Your problems should be gone. Let us know.
Message 23 of 61
Highlighted
I really hope so. Am going to hook it up right now and update.
Message 24 of 61
Highlighted
Guru
Let us know. I recommend doing a factory reset and setup from scratch on the RBR after v10.11 is applied.
Message 25 of 61
Top Contributors
Discussion stats
  • 60 replies
  • 1422 views
  • 6 kudos
  • 12 in conversation
Announcements
