Orbi WiFi 7 RBE973
Reply
ORBI AX with Surfboard
gglazer
Looking at getting an Orbi because the current router doesn't reach some parts of the house.
However, we currently have an Arris Surfboard SVG248AC which is both modem AND router. So, if I plug the Orbi into the Surfboard, I'm not just plugging it into a modem, I'm plugging a router into a router. Will this configuration work or will I need to figure out how to turn the Surfboard's router functionality off or buy a modem only unit?
Thanks,
Glenn
Message 1 of 6
Accepted Solutions
Guru
Re: ORBI AX with Surfboard
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 6
All Replies
Guru
Couple of options,
Message 2 of 6
gglazer
Many thanks for the complete response.
Message 3 of 6
Guru
Smiley Wink
Message 4 of 6
gglazer
Just for the record, the Surfboard does have a bridge mode:
https://arris.secure.force.com/consumers/articles/General_FAQs/TG862G-NA-Bridge-Mode-Setup
Message 5 of 6
Guru
Something to try out for sure.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 771 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
