- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI AX6000 with Satellite VPN susceptible to Man in the Middle Attack
- Mark as New
- Bookmark
- Subscribe
- Permalink
ORBI AX6000
Firmware V3.2.18.1_1.4.14
OpenVPN Server/Client
I turned my logging up to 5 in the config.
WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Important Note on possible "Man-in-the-Middle" attack | OpenVPN
I did a google search and found this in this community:
Solved: OpenVPN warning: No server certificate verificati... - NETGEAR Communities
but it's not solved on the AX6000's on this firmware. I added this to the last line: "remote-cert-tls server". I now get the following error in my openvpn, and it continues cycling like this, and failing on validation
2021-05-01 13:51:54 us=563806 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
2021-05-01 13:51:54 us=563806 Certificate does not have key usage extension
2021-05-01 13:51:54 us=563806 VERIFY KU ERROR
2021-05-01 13:51:54 us=563806 OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
2021-05-01 13:51:54 us=563806 TLS_ERROR: BIO read tls_read_plaintext error
2021-05-01 13:51:54 us=563806 TLS Error: TLS object -> incoming plaintext read error
2021-05-01 13:51:54 us=563806 TLS Error: TLS handshake failed
2021-05-01 13:51:54 us=563806 TCP/UDP: Closing socket
2021-05-01 13:51:54 us=563806 SIGUSR1[soft,tls-error] received, process restarting
2021-05-01 13:51:54 us=563806 MANAGEMENT: >STATE:1619902314,RECONNECTING,tls-error,,,,,
2021-05-01 13:51:54 us=563806 Restart pause, 5 second(s)
Here is my client1 configuration, without my URL(sorry guys, I'm not open to the world here).
client
dev tap
proto udp
sndbuf 0
rcvbuf 0
auth-nocache
allow-compression no
push "sndbuf 393216"
push "rcvbuf 393216"
dev-node NETGEAR-VPN
remote *.mynetgear.com 12974
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
data-ciphers AES-128-CBC
comp-lzo no
verb 5
This works, but throws the MITM issue up as a possiblity. when I add the fix, it doesn't work at all... I even looked up those errors and it told me to remove "remote-cert-tls server" from the configuration. So it's run less secure, or not at all. Can someone please help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI AX6000 with Satellite VPN susceptible to Man in the Middle Attack
Best off to report this to NG support. Would be nothing that the forum can help with.
https://www.netgear.com/about/security/
Good Luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did that, and thankfully I've got support on this product. I'll try to remember to post the recommendations/update once Netgear responds and/or fixes it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any updates on this issue?
I'm dealing with another VPN issue where Open VPN seems poorly configured. Wondering how I can get Netgear to fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Best way would be to contact NG support and let them know what your seeing.
