Reply
Older Wifi Devices Not Connecting to Orbi Wifi 6
njsteblay
Tutor
Orb Wifi 6 - Orbi AX6000 Tri-band Mesh WiFi 6 System
Model: RBK852
I have an older Insignia Google Home device that connects fine to my older Wifi Router but won't connect to the Orbi Wifi 6.  Any suggestions for configuration that allow older devices to connect?
Message 1 of 5
Accepted Solutions
njsteblay
Tutor
Re: Older Wifi Devices Not Connecting to Orbi Wifi 6
Yes, I posted in the other forum as directed.  I increased the CTS/RTS Threshold  to 2347.
Message 4 of 5
All Replies
CrimpOn
Sensei
You are more likely to get an informed response by posting in the community forum for the WiFi 6 (AX) product line:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Those of us who watch this forum mostly have the residential WiFi5 products.
Sorry.
I love my Orbi.
Message 2 of 5
Guru
Any progress on this?
Are you using the same SSID name and PW as what you used on your prior router?
Model: RBK852
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK50 v2.7.2.104(WW)/RBK853 AP Mode v3.2.18.1
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 3 of 5
njsteblay
Tutor
Message 4 of 5
Guru
And did this resolved your issue? Looks like it.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1522 views
  • 0 kudos
  • 3 in conversation
Announcements
