TexARC
Nov 24, 2020Guide
Orbi 750 and 2.4gHz SSID
Is there any way to attach a 2.4gHz device (Ambient Weather Station) to Orbi? IOW, the device scans but cannot see an SSID for 2.4gHz. I'm currently on hold with the 6th tech support person at NetGear, apparently no one can find anyone that knows about Orbi, but they promise to find someone to transfer me to that can help me.
I have two Nghthawk x4S AC2200 Model EX7500 mesh extenders, which MIGHT broadcast 2.4gHz if I could only figure out how to attach one to Orbi. Is THAT a possibility?
Disable AX mode on the RBR.
Might try setting CTS value to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
- TexARCGuidewhen I installed the orbi it did a firmware upgrade as part of the installation process, so I would have to guess from a distance that it is the latest version. I can check when I get home from work in about 12 hours. thanks.
Let us know if some of the suggestions work as well...
Check with the mfr of this device as well to see if they have any help and information. Ensure it's software or firmware is up to date.
- TexARCGuide
Might try setting CTS value to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings"
Hi. The firmware is the latest according to netgear -
Firmware Version
V3.2.16.6_1.4.4I've gone through and disabled 5mHz options throughout, as well as AX mode and setting CTS value to 2347 , the scanner on the weather station cannot see any wi-fi network. My efforts continue. :)
Can try updating FW to see:
https://community.netgear.com/t5/Orbi-AX/New-Firmware-Out-Today/m-p/2005684/highlight/true#M9268
Sounds like the device is not compatible or have the ability to see Smart Connect enabled wifi signals. I would recommend contacting the mfr of trhis device and ask them about this. Possible there wifi drivers are not up to date enough to see whats being broadcast by Orbi.
TexARC wrote:"
Firmware Version
- TexARCGuidethanks, but the ambient weather station has its own scanner for 2.4gHz and setup, no phone app.
