- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi AX4200 Router and AX4200 Satellite - Can you disable Microphone
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible to disable the microphones on the Orbi AX4200 Router and AX4200 Satellite devices?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AX4200 Router and AX4200 Satellite - Can you disable Microphone
Microphone? I don't believe there is anything of the kind on network routers...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe I am missunderstnding this feature on the website:
- Works with Amazon Alexa and the Google Assistant so you can use voice commands to control your home WiFi network.
So, the unit itself doesnt have a microphone and doesnt have Alexa or Google Assistant capabilities? I thought I read someone was having issues with those features.
Thanks,
Justin
@FURRYe38 wrote:Microphone? I don't believe there is anything of the kind on network routers...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya the Orbi doesn't have a microphone. I may work with Alexa enabled devices like Echo Dots or if you install a RBS40v which V is for Voice. Otherwise the Orbi AX itself is just a wifi system only. No Voice.
