Orbi WiFi 7 RBE973
Reply
Orbi AX6000-Is it compatible with FIOS
burnz123
Follower
Is this product compatible with FIOS?  If so, is there set up directions available somewhere to assist me in the set up?
Message 1 of 3
Guru
Re: Orbi AX6000-Is it compatible with FIOS
It should. Sometimes you have to change some settings to get it working.
https://kb.netgear.com/23977/Will-my-NETGEAR-router-work-with-Verizon-FiOS
Message 2 of 3
Guru
Be sure to post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1116 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
