Orbi WiFi 7 RBE973
Reply
Orbi AX6000 detached garage no insulation
marine0816
I know the operating range is 32 to 104 degrees(F). But I'm looking for any real world usage of the satellite in an enclosed in environment with no insulation. I know the previous gen has an outdoor version but I'm not interested in that. Putting it in the detached garage is the only way my nest and ring cameras will stay connected. My climate is Pennsylvania.Thanks
Message 1 of 2
Guru
Re: Orbi AX6000 detached garage no insulation
No experience here. If the garage is not insulated then depending upon wet and humidity conditions, this may impact operation of an indoor orbi system since it's designed and meant to be inside mostly insulated buidings where wet and humidity conditions are kept out and controlled.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 517 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
