Orbi WiFi 7 RBE973
Reply
Orbi RBK752 No Internet Connection
duffymo
Xfinity is my ISP.  The cable modem connecting to the internet is locating in a room above my garage, connecting to my desktop.  I extend wi-fi through the downstairs portion of my house using three of their wi-fi extension pods.
I purchased an Orbi RBK752 in hopes of improving my wi-fi access.
i logged into my Xfinity modem as admin, enabled bridge mode, and restarted the modem.
I powered up both the Orbi router and satellite, connecting the cable modem to the router using Ethernet port #4.  I set up the Orbi network using the iPhone app.  It said it had no problem getating an Internet connection.  I completed the setup and came downstairs to check the satellite.  It showed a blue light, which means the connection was strong.
I got on my laptop and saw the Orbi network as a choice for wireless connection.  I chose the Orbi network and entered the password.  My phone told me that it could see both my iPhone and my Ubuntu laptop connected to the Orbi wi-fi network.  It looked like I'd done everything correctly.
I was disappointed when my laptop could not access any web pages.  No hosts could be resolved; no DNS server was visibile.  It was as if there was no connection to the Internet, in spite of the feedback on my phone.
I had to disconnect and turn off the Orbi router and satellite and restore the Xfinity extenders to restore Internet access.
What did I miss?  Why couldn't my laptop find a DNS server when the network said an Internet connection was available?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 5
Guru
Re: Orbi RBK752 No Internet Connection
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Power OFF the ISP Modem and RBR for 1 minute. Then back ON with the modem first, then the RBR. Be sure to use port #1 on the modem for the RBR ethernet cable.
Message 2 of 5
duffymo
How to move a question?  Copy, paste, and create a new question?  Or is there a better way.
Already did all that.  No joy.
Message 3 of 5
duffymo
Xfinity voice and data modem:
CISCO DPC3941TSerial #: 48F7C0D3CE0D
Firmware is up to date.
Message 4 of 5
Guru
Your ISP modem already has a router built in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Try option 3 first to see if this works.
Be sure your using a good quality LAN cable between the modem and Orbi router. CAT 6 is recommended.
Be sure you use LAN#1 port on the back of the modem...
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1265 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
