- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK850 Speedtest Not Working
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have RBK850 with three RBS850 satellites and after one day the Speedtest on the Orbi App and on the QoS setup on the Orbi Web interface have not worked.
When I try to run the speedtest I keep recieving a message 'Connection Failed", although the sysetm is working normally.
I have been in contact with Netgear support several times and they have been telling me for two weeks that it is a known issue and will be resolved within 1-2 days....
Does anyone else have the same issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK850 Speedtest Not Working
I wouldn't use the built in speedtest app regardless. its good to check/prove theres a a connection but it rarely picks the best server for speedtesting. Its one of the issues we see when people say "my orbi isn't getting full speed" and they're testing off the built in speedtest.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Be to to compare speed results with Ooklas installable speed test app on a wired PC or laptop.
Thank you.
@PeterHK wrote:I have RBK850 with three RBS850 satellites and after one day the Speedtest on the Orbi App and on the QoS setup on the Orbi Web interface have not worked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I'm having the same problem. I have an RBR750 with 2 satellites. Like you, mine worked at first, then after a few days, I started getting the connection failed error. I also contacted Netgear, but they did not say this was a known error when I called. I still have the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @PeterHK and @Fritzsche0529
Welcome to NETGEAR Community!
Please provide the following information:
- Router firmware version
- Orbi App version
- Android and/or iOS version
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi app 2.6.2.9
Orbi firmware V3.2.16.6
iOS 13.7
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please make contact with NG forum moderator about this. Maybe something on there side of the fence regarding this that they need to address. In meantime, you can use Ooklas installable speedtest app to check speeds.
@Cshartma wrote:
I have the same problem on my RBR850. The app, router and iOS versions are all the latest levels. I’ve deleted the app and reinstalled. Still no speed test capability. My ISP is Charter at 1Gig speed. All else is fine. The speedtest worked from March through about August time frame. I think the router did a firmware update just about then. I’ve called netgear support. They were useless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am pretty sure this is a Netgear server-side issue. My speedtest also stopped working -- shows the results from a speedtest back in July and wont renew.
Have current firmware and nothing has changed - so I suspect this has to do with Netgear resources outside of the LAN.
The remainder of the RBR850 appears to be working well -- even logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I have the same issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a hard reset of my 850 and it all came back to normal
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you speed testing wireless or wired?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
@JanSt wrote:Yes, I have the same issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Hereford85 wrote:
I have this exact same issue and have tried everything to get around it. Nothing seems to help it though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same problem here. Wish I never would have bought this buggy $1000+ Albatross.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@C4H7 wrote:Same problem here. Wish I never would have bought this buggy $1000+ Albatross.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware: V3.2.16.22
Motorola MB8600
- Mark as New
- Bookmark
- Subscribe
- Permalink
New RBR850 / RBS850 Series Firmware Version v3.2.17.12 Released
New Features and Enhancements:
Supports the new device notification feature
Includes some security enhancements
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Bug Fixes:
Fixes issues with Speedtest in the Orbi app
Fixes device access issues with the web UI
Fixes some web UI related issues
Download Link:
https://www.netgear.com/support/product/rbk852.aspx#download
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My SpeedTest has been working for months since my last factory reset. I had to reboot my router yesterday, and the SpeedTest stopped working again. I don't want to do the factory reset if I can avoid it. I see that there is a FW update available, but it does not appear to be available for my system, or maybe just not in my area. Any intel on the FW update? I have 3.2.16.22...and am not given an update option to 3.2.17....
- Mark as New
- Bookmark
- Subscribe
- Permalink
" I have 3.2.16.22...and am not given an update option to 3.2.17....".
I have the same situation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just did a manual update of the router and satellites to RBR850 / RBS850 Series Firmware Version v3.2.17.12 at the Orbilogin website. Speedtest is now working again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
v12 is here and currently has to be manually downloaded to the RBS first then RBR using a PC or latop:
@Fritzsche0529 wrote:My SpeedTest has been working for months since my last factory reset. I had to reboot my router yesterday, and the SpeedTest stopped working again. I don't want to do the factory reset if I can avoid it. I see that there is a FW update available, but it does not appear to be available for my system, or maybe just not in my area. Any intel on the FW update? I have 3.2.16.22...and am not given an update option to 3.2.17....
