Orbi WiFi 7 RBE973
Reply
Orbi RBS50 won't play nice with my printer, can I add a Netgear AP to help?
pcasa
Follower
Mesh is a RBK52.  Printer is a Epson WF-7840.
Already did the Channel 11 and changed CTS/RTS to 2347.
Printer connects, but connection speed is 2mbps.
Can I add a RBS10 as a satelllite or repeater? If not, can I add a access point like a WAC104 so I can physically connect from AP to Printer?
Old eero mesh had no problem with this printer before, so doubt it's the printer.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi RBS50 won't play nice with my printer, can I add a Netgear AP to help?
Orbi AC series are not wirelessly compatible with AX systems. You can ethernet connect RBS to the AX system and would work that way:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 340 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
