- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Orbi SpeedTest not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi SpeedTest not working
I took mines back to Best Buy due to some issues it was having including the speedtest randomly not working. Swapped to another one to give it another try. Everything works again.
im curious to see if In a few days everything goes to shizz again and the speedtest stops working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, I put my RBR850 online last nite in AP mode. Checked today and Orbi app on my phone and Android app are working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
so in AP mode it works for you? but in router mode it doesnt ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something I'll try later on this weekend. I'm currently testing AP mode and NEST controller problems. I have no doubt there is a orbi app issue and it's probably on NG side of the fence. Again, users are encouraged to make contact with NG support and post over in the Orbi app forum regarding this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well it is working fro you in AP mode, Great! Good news. Let us know in two weeks if it is still working?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please make contact with NG support if you haven't already and let them know what your seeing.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I shut down my network, restarted, there may have been a firmware upgrade (can't tell) but Orbi Speedtest works fine now, easy-peasy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you mean by shut down? Power off the RBR? Just curious what you did.
Yes if there was FW update, it's recommended to power OFF the RBR and RBS for 1 minute then back after the udpate.
@tedmichon wrote:I shut down my network, restarted, there may have been a firmware upgrade (can't tell) but Orbi Speedtest works fine now, easy-peasy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Awesome. Let us know if you see the speed test app stop again. Hopefully it won't. Mine hasn't.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi SpeedTest not working on RBR and RBK 6K
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had tried rebooting my router and other components multiple times with no luck. I was able to contact NG support (Rose) and she suggested that I do a factory reset. She walked me through it and actually did most of the reset remotely. It was then necessary to do a new system setup for my router. Rose stayed on the line while everything rebooted. When I tried the SpeedTest upon full system startup, it worked. It has been working since last Friday. It took about an hour, and I had to clear my schedule and family's schedule to enable full shutdown of my WiFi, but in the end, everything is working great now. I hope it works for you, too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know. So both RBR speed test app and Orbi app now work for you?
Please mark your thread as solved so others will know.
Enjoy.
@Fritzsche0529 wrote:I had tried rebooting my router and other components multiple times with no luck. I was able to contact NG support (Rose) and she suggested that I do a factory reset. She walked me through it and actually did most of the reset remotely. It was then necessary to do a new system setup for my router. Rose stayed on the line while everything rebooted. When I tried the SpeedTest upon full system startup, it worked. It has been working since last Friday. It took about an hour, and I had to clear my schedule and family's schedule to enable full shutdown of my WiFi, but in the end, everything is working great now. I hope it works for you, too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am glad this worked for you. It is next on my list too but I have to ask What firmware level are you at now? is it the same as before you reset or did it roll back?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm currently on v6.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is the same as before (the current version). V3.2.16.6-1.4.4. It was not rolled back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBR750, it's pretty extreme do be doing a factory reset if you have a lot of connections to manage.
Did you have to connect all the clients back or did you basically use the same settings and just had to do them over on the router side after the factory reset?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Manokski, I did not have to manually reconnect any of the devices after my reset. Everything stayed the same after the factory reset, but I should note that I had not changed the WiFi name or password during my original setup..thus, it's the same as it was before. I don't suspect that you would have to do anything other than ensure that the "reset" router has the same SSIDand password as what you had previously. If so, the devices should reconnect without issue. I should note that I'm not an IT whiz, so I hope I didn't misinterpret your question.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also after a reset and setup from scratch and you have the wifi setup for your system, I recommend backing up the configuration to file for safe keeping. Saves time if a reset is needed...
- « Previous
- 1
- 2
- Next »
