Orbi WiFi 7 RBE973
Reply
Orbi SpeedTest not working
suzimogavero
Orbi SpeedTest not working up until three weeks ago.  Cannot find the issue as to why it would just stop working.  Very dissapointed in Netgear as I paid top dollar for this mesh system and you would think they would have all of the kinks worked out.
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 16
Guru
Re: Orbi SpeedTest not working
What model Orbi do you have?
Is the speed test app on the router not working or is the Orbi app speed test not working?
Can't assume it's NG fault until we get more details and troubleshoot the problem.
Message 2 of 16
Neuton
Tutor
I have the same issue.  I called Netgear support, what a disappointment they are.   No solution, they want me to spend my time helping them document the issue. Also, the wired and wireless speed are terrible.  Meanwhile I shelled out $500 for this frustration and dissatisfaction.
Firmware: 3.2.16.6
Verizon FIOS 1Gb - Router Verizon G3100
Message 3 of 16
Guru
Are you testing with a wired or wireless device?
Firmware: 3.2.16.6
Message 4 of 16
Guru
What node is your modem working in? If router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Firmware: 3.2.16.6
Message 5 of 16
Neuton
Tutor
RBK 753 Firmware: 3.2.16.6
Verizon Router G3100
ONT Verizon I-211M-L
The speed test fails on both.   Using Speedtest.net shows very slow speeds both on wired and wireless connections.
Message 6 of 16
Guru
Message 7 of 16
Neuton
Tutor
Node 1.  It is the only node being utilized,.
Message 8 of 16
Guru
Oops, typo on my part. Sorry. Meant to say what MODE is your modem working in? Router or bridged?
Message 9 of 16
Neuton
Tutor
Verizon Router is in bridge mode, Orbi Router mode
Message 10 of 16
Guru
Ok.
You might try newer FW, load on the RBS first then RBR then factory reset, power OFF the modem for 1 minute then back on, then walk thru the setup wizard. I would not enable Armor. Run a speed test with a wired PC and Ooklas installable speed test app on the PC first.
https://community.netgear.com/t5/Orbi-AX/New-Firmware-Out-Today/m-p/2005684/highlight/true#M9268
Message 11 of 16
Neuton
Tutor
I have the newest firmware that is publically available.  I have performed a factory reset on the router and satellites and manually loaded the a fresh copy of the newest firmware in the exact order you described.
I appreciate you help with this.  This thing cost $500.  I should. not have to do all this to make it work correctly.  I am going to return it.
Message 12 of 16
Guru
Ok, sorry it didn't work out.
Good Luck.
Message 13 of 16
Guru
Any progress on this?
@Blanca_O
Message 14 of 16
suzimogavero
No progress. Rebooted and same error. What a joke.
Message 15 of 16
Guru
Try udpating FW:
Orbi speedtest app is working for me:
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 1897 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
