Reply
Orbi WiFi 6 Passwords
Cerbeus
Initiate
I'm trying to change my Orbi password but I'm having a devil of a time doing it.  It would help of course to know Netgears policy regarding router passwords which I know nothing about.  Is there a maximum length  they can be?  6? 10? 15?  20?  25? 30? Well I know the minimum length but again I'm not sure if there is a maximum one.
I'm using the "acceptable" symbols I think but yet nothing seems to be happening when I click on "change password". Any advice?
Message 1 of 4
Accepted Solutions
Guru
Re: Orbi WiFi 6 Passwords
Are you chaning the admin log in paswword?
if so, then NG likes 1 capital and a number in the mix and a minimum of 8 characters. NGorbi850 for an example.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK50 v2.7.2.104(WW)/RBK853 AP Mode v3.2.18.1
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 4
All Replies
Guru
Message 2 of 4
Cerbeus
Initiate
Thank you,.  Found a easy solution, it was right in front of me the whole time but thanks for trying to help.
Message 3 of 4
Guru
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 350 views
  • 2 kudos
  • 2 in conversation
Announcements
